Mar 15
Hi, I'm having an annoying problem with macOS. When I record something using Superwhisper (SW), all the text is saved correctly in "History," but not in the text field of the app I'm currently using.
I have the same !! very annoying
I changed my clipboard app. The clipboard app I used was interfering with superwhisper. Since I changed it superwhisper work's perfectly.
I don't have any clipboard app, but the error append when I using local AI, on cloud's one everything work just fine
