Mar 21
Custom Mode Toggle Options for Recording UI, Auto-Pasting, and Auto-Close
I would really appreciate a possibility for each custom mode to select whether I want this UI interface for recording to pop up, whether the automatic pasting should be enabled, and whether this recording window should be automatically closed after recording. In the shortest explanation possible: I would like to have three toggle buttons in the custom mode configuration only. This way, the behavior will adapt to the use case and the selected custom mode. I know that one of the YouTubers promoting Superwhisper is dealing with this problem using Keyboard Maestro automation, which allows switching between those options with a shortcut. However, based on the different nature of custom modes, it would be really awesome to have these features integrated.
yes please!!! similar to this: https://superwhisper.userjot.com/board/p/separate-settings-p…
